1955 Suburban Sliding Glass Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Plazaman |
Member Posts: 39 | Looking for good rubber seals for the Sliding Glass assembly for a 2-Door Suburban. | ||
Old Ray |
Extreme Veteran Posts: 507 Location: Invermere B.C. Canada - Rocky Mountains | Plazaman - 2020-10-07 5:01 AM Looking for good rubber seals for the Sliding Glass assembly for a 2-Door Suburban. Good luck, to the best of my knowledge it is not sold as specfic to that application as a part number, certainly not listed by Steele, I also think not by the other high priced poor service suppliers that I will not deal with any more. BUT, there is a hope, on my 2 door Suburban I cut the old rubber and using the cross section and the Steele universal listings and came up with the rubber that I think will work. There are two different rubbers on the sliding side windows, one is used to hold the fixed glass in that has a lip to the outside and this rubber is also used on the back side windows, and there is a U channel stiffer rubber that is for the sliding glass. I have both of these and have quickly test fitted the lipped one and it looks good so far. They might not be exact but they are close, ... like there is a choice. So you can do what I did ... or I will get you the part numbers for you with sufficient pleading on your part and when I feel like it. (1956 plymouth body back on (640 x 480).jpg) Attachments ---------------- 1956 plymouth body back on (640 x 480).jpg (89KB - 226 downloads) | ||
Plazaman |
Member Posts: 39 | Old Ray, thanks for the help and the humor! I have gone the same route as you. I actually live close to Steele Rubber and have purchased some pieces. But like you, it will take some creative gumption to make anything work. I was hoping there would be someone out there that has a parts car with the rubber intact because I'm lazy and anything from the OEM has got to fit better than what I will come up with. | ||
Plazaman |
Member Posts: 39 | Old Ray, what did you use for your subframe? | ||
Old Ray |
Extreme Veteran Posts: 507 Location: Invermere B.C. Canada - Rocky Mountains | Plazaman - 2020-10-07 9:55 AM anything from the OEM has got to fit better than what I will come up with. Are you sure, I think (hope) that I am fairly close, we can exchange part numbers someday. | ||
Old Ray |
Extreme Veteran Posts: 507 Location: Invermere B.C. Canada - Rocky Mountains | Plazaman - 2020-10-07 9:56 AM Old Ray, what did you use for your subframe? Dakota. The frames at the sweet spot (just before the front body mount) are exactly the same size. | ||
Old Ray |
Extreme Veteran Posts: 507 Location: Invermere B.C. Canada - Rocky Mountains | Plazaman, I sent you a PM. | ||
Darryl T |
Extreme Veteran Posts: 429 Location: McCleary WA | Old Ray - 2020-10-07 7:23 AM I will get you the part numbers for you with sufficient pleading on your part and when I feel like it. Any chance of getting the Steele part number for the lower sliding window U channel seal you used? I'm doing a '57 Dodge 2-door wagon and can't find anything that will fit. I got the fixed glass seal from Goers, but neither he nor Quirey have been able to provide the lowers. And I didn't see anything in Steele's online catalog that looked right. Any help would be appreciated. | ||
Expert 5K+ Posts: 9911 Location: Lower Mainland BC | . Is that channel a metal "U" lined with fuzzy material? If so, it is likely that your local Old (Chevy and Ford) Car Centre will have very good stuff . At mine I got one stick of the wider channel with the chrome (stainless) edges for the rear vertical and upper horizontal piece (one piece, bent) . It was called ZRC-528 and was $40 for the 8 ft section. Measured the old one and it was a tad over 48" so the one stick will do two front doors for that piece. The other stick is a Y-614 "Rigid Vent Channel" and it fits inside the vertical frame that extends down from the rear of the vent window. The length looks to be 29" so 8 ft might do three doors. $32 for the 8ft stick. It has stainless edges. I am guessing that the Y-614 will work for your slider, at least at the bottom and the ZRC-528 might be answer for the upper bendy bits. | ||
Old Ray |
Extreme Veteran Posts: 507 Location: Invermere B.C. Canada - Rocky Mountains | Darryl T - 2021-01-12 6:02 PM Any chance of getting the Steele part number for the lower sliding window U channel seal you used? I'm doing a '57 Dodge 2-door wagon and can't find anything that will fit. I got the fixed glass seal from Goers, but neither he nor Quirey have been able to provide the lowers. I do not know if the '55-'56 is the same as the '57. Not sure what you mean by lower ?
Darryl T |
Extreme Veteran Posts: 429 Location: McCleary WA | The lower track/seal the sliding window sits in. It appears to be U-shaped, 1/2" wide and 1/2" high with a lip on one or both sides maybe 3/4" wide. My original is too far gone to be sure what it should look like. | ||
Old Ray |
Extreme Veteran Posts: 507 Location: Invermere B.C. Canada - Rocky Mountains | Darryl T - 2021-01-12 8:59 PM The lower track/seal the sliding window sits in. It appears to be U-shaped, 1/2" wide and 1/2" high with a lip on one or both sides maybe 3/4" wide. My original is too far gone to be sure what it should look like. I think the track/seal goes all the way around the sliding window. https://www.steelerubber.com/unbeaded-rubber-channel-70-3577-58 Edited by Old Ray 2021-01-13 9:01 AM (sliding window rubber.jpg) Attachments ---------------- sliding window rubber.jpg (26KB - 173 downloads) | ||
Darryl T |
Extreme Veteran Posts: 429 Location: McCleary WA | My original seal appears to have had a 3/4"-1" lip on the outside that laid on the body, and maybe one on the inside too. All I have left is the channel and a lip halfway down, for both sides of the car. | ||
Old Ray |
Extreme Veteran Posts: 507 Location: Invermere B.C. Canada - Rocky Mountains | Darryl T - 2021-01-13 12:10 PM My original seal appears to have had a 3/4"-1" lip on the outside that laid on the body, and maybe one on the inside too. All I have left is the channel and a lip halfway down, for both sides of the car. Yes, that is the other number, the fixed non-sliding glass one (I think). I have trial fitted it and it looks OK. (good enough for a fat old turd anyway).
(window rubber seal 2.jpg) Attachments ---------------- window rubber seal 2.jpg (27KB - 179 downloads) | ||
Old Ray |
Extreme Veteran Posts: 507 Location: Invermere B.C. Canada - Rocky Mountains | Darryl T - 2021-01-13 12:10 PM My original seal appears to have had a 3/4"-1" lip on the outside that laid on the body, and maybe one on the inside too. All I have left is the channel and a lip halfway down, for both sides of the car. SO, ... is that of any help ?
Darryl T |
Extreme Veteran Posts: 429 Location: McCleary WA | Possibly. The second one, with the lip, appears to be for setting fixed glass. The sliders need to be able to, well, slide. I'm still looking. I may end up with a combination of the first plus a lip seal. | ||
