1959 Dodge Sierra D500, tag-question Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Gunnarback |
Member Posts: 9 | Hi. curious what "everything" means, but I am most curious about what one (1) under the M5 stands for. Tnx, Gunnar (CC9B55BB-6127-4F90-B962-FAA92BE3738F.png) Attachments ---------------- CC9B55BB-6127-4F90-B962-FAA92BE3738F.png (102KB - 228 downloads) | ||
Expert 5K+ Posts: 9924 Location: Lower Mainland BC | Gunnarback - 2020-12-24 2:06 PM Hi. curious what "everything" means, but I am most curious about what one (1) under the M5 stands for.Tnx, Gunnar Your previously posted photo is better: | ||
frwl |
Expert Posts: 1924 | . As stated by d500neil on red Coronet 2 door sedan in this thread: The "M5-1" number confirms the 2-barrel carb version of the 326 V/8 engine. http://www.forwardlook.net/forums/forums/thread-view.asp?tid=14212&... | ||
ronbo97 |
Expert Posts: 4051 Location: Connecticut | frwl - 2020-12-25 9:53 AM . As stated by d500neil on red Coronet 2 door sedan in this thread: The "M5-1" number confirms the 2-barrel carb version of the 326 V/8 engine. Gunnar's car is a Custom Royal. So that theory doesn't hold water. Neil knew 57 Dodges. But 59 Dodges ? Not so much. Ron
Gunnarback |
Member Posts: 9 | I have understood that 3 before 1 means that it is a 4 barrel carb on the 383 | ||
frwl |
Expert Posts: 1924 | . I'm not claiming anything – I just got a link. I know that code M2 = 3 = 373 is a D-500 engine; and I guess that code M2 = 4 = 374 is a Super D500 engine I don't quite understand Neal's statement either… | ||
frwl |
Expert Posts: 1924 | . Hello Gunnar I am also guessing that the code M1 = 8 is the locked luggage compartment (code 328). It was standard on 9-passenger wagons and as an option on 6-passenger wagons. Can you confirm or deny this? Thanks | ||
frwl |
Expert Posts: 1924 | . http://www.forwardlook.net/forums/forums/thread-view.asp?tid=74984&... | ||
frwl |
Expert Posts: 1924 | . I know: this is 59 Plymouth; not 1959 Dodge, but still... | ||
frwl |
Expert Posts: 1924 | . 377 = Dodge Sierra Spectator 4door Station Wagon, 9P 379 = Dodge Custom Sierra Spectator 4door Station Wagon, 9P These models have locked luggage compartment as standard; so their M1 space are empty; 376 = Dodge Sierra 4door Station Wagon, 6P 378 = Dodge Custom Sierra 4door Station Wagon, 6P These models have not locked luggage compartment as standard; so their M1 space are empty; If these have it; so their M1 space stamped by 8… That’s the difference, I guess… | ||
Gunnarback |
Member Posts: 9 | Hi frwl. the opions (i guess) on the car is: -swivel seats -padded dash -padded steering wheel -clock map lighting -chromed stone protection -9 p -D500-1 -back up lights -roof rack with caddy bulits lights -variable windscreen wiper -windshield washer -power steering -power brakes -Radio -speed limiter Edited by Gunnarback 2020-12-26 4:07 AM | ||
frwl |
Expert Posts: 1924 | . M5 - 1 code could be: 361 - Swivel Seat 391 - Auto Headlamp Dimmer 501 – Undercoating Do you have a broadcast sheet of this car for check these? There has been a discussion about this: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=68862&... | ||
Gunnarback |
Member Posts: 9 | I forgot, the 391 and 501 (at least under the front fenders) is also in/on the car | ||
frwl |
Expert Posts: 1924 | . If you have been reading – RDP said in the thread that I posted above: «M5 1 - maybe swivel seat or undercoating, my car has no dimmer» So the M1 code could be either swivel seat or undercoating The search circle is narrowing… | ||
frwl |
Expert Posts: 1924 | . What about a broadcast sheet? | ||
frwl |
Expert Posts: 1924 | . I seem to have solved the «?1 code» mystery in the link I posted yesterday – here it is: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=14212&... The red Coronet 2 Door Sedan with the code M1 = 5 on the tag is shown there, but it does not have swivel seats. Therefore the code M1 = 5 = 501 is UNDERCOATING, I guess. Anyway, the broadcast sheet (IBM card) would be confirmed this guessing… (1.jpg) (2.jpg) Attachments ---------------- 1.jpg (68KB - 223 downloads) 2.jpg (73KB - 229 downloads) | ||
frwl |
Expert Posts: 1924 | . Sorry, wrong link; it doesn't work... Try this: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=14212&... | ||
RDP |
Elite Veteran Posts: 1049 Location: PL / EU | Here another old thread about M-codes. This is about 59Plym, but has some interesting info. http://www.forwardlook.net/forums/forums/thread-view.asp?tid=42970&... . | ||
frwl |
Expert Posts: 1924 | . Robert: If you know it already, look at next 1959 Dodge M-codes: M1 = 8 = 328 = Locked Luggage Compartment for 6-passenger Wagons (it has optional lock cylinder on the picture) M6 = 5 = 305 = Power Tail Gate Window for 6-passenger Wagons too (it should have crank tail gate handle as standard equipment) What do you think? (1.jpg) (2.jpg) Attachments ---------------- 1.jpg (240KB - 232 downloads) 2.jpg (220KB - 230 downloads) | ||
frwl |
Expert Posts: 1924 | . And finally could it be: M1 = 7 = 327 = Radio Rear Shelf Speaker | ||
