electric choke Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
billy |
Extreme Veteran Posts: 395 Location: upstate new york | what are others thoughts on the electric choke upgrade? i have the original system that comes off the exhaust manifold, but is suspect because of questionable connections. Have others upgraded to the electric choke? When i watched the video on it, it looks like it wires to a ballast resistor...i had a ballast resistor on my 72 Cuda but not sure if 1 exists on my 57 New Yorker...thoughts? thanks, billy | ||
Expert 5K+ Posts: 7401 Location: northern germany | Restore the factory system, as it "monitors" the actual temperature of the intake manifold. Even if its not much, the e-choke constantly draws current and it is just another electrical item to go bad. I'm such a fan of the divorced OE choke, that I even converted the E-choke of the aftermarket Holley carburetor I'm running to the divorced choke system. Works without problems. | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | . My car came to me already equipped with an Echlin electric choke comprised of an electrical relay, the choke activation element (a plate with an electrically heated bi-metal spring) and the wiring, as shown below. As Sid suggests, it is on as long as the ignition key is in the RUN position (IGN on the switch). I haven't had a problem with it. I doubt that it is sucking very many amps. They are available from NAPA: https://www.napaonline.com/en/p/CRB21663 That said, if I had the OE components (which I do not), like the heat tube, the insulation, the mechanically heated choke disc, I would be just as happy or maybe even happier. I would make my 56 Dodge look like this 1955 Dodge, choke-wise: But for me to go Sid's OE way, I would have to find the hot-air cover, the air tube and the insulation. I can find the cover on eBay. Probably have to make the hot air tube. https://www.ebay.ca/itm/1957-65-Corvette-Carter-WCFB-Single-Carburet... Edited by 56D500boy 2021-01-19 10:45 AM | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | What Sid wrote... Electric choke is absolutely not an upgrade, more of a downgrade That said, yes there is a ballast resistor on the firewall up on the left side. Connect it to the 12 volt side. Make sure that your heat riser isn't rusted/seized in the wrong position. | ||
billy |
Extreme Veteran Posts: 395 Location: upstate new york | Thanks Gents...I'll re-inspect current setup and see if i can repair...thanks for the help....that's a nice looking engine and engine compartment....I have a ways to go to get there. | ||
Expert 5K+ Posts: 9672 Location: So. Cal | Dave, your 315 should use an intake manifold choke, not the exhaust heat version, no? All my 325 motors use the later type intake choke. Billy, yes, the electric choke works if you can't use an original. The main problem with them that I have had is if you shut your hot car off, and come back after 15min, your engine is still hot, but your electric choke is now cold. So when you go to crank it, the motor will likely flood out on you because it has the wrong choke setting. To get around it, you have to know ahead of time what it is likely to do, and give it full throttle when you start it to prevent that from happening. | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | Powerflite - 2021-01-19 8:53 AM Dave, your 315 should use an intake manifold choke, not the exhaust heat version, no? All my 325 motors use the later type intake choke. Nope. They didn't change to the Timmy-down-the-well style until 1957. The 56s (hemi and poly) follow the 55 style (which maybe goes back to 1953, Dodge's first V8s??) First a photo of a 57/58 4bbl intake showing Timmy-down-the-well and then mine (when I was investigating air cleaner options): Edited by 56D500boy 2021-01-19 3:12 PM (58Dodge4bblIntake1735774.jpg) (315HemiRightExhaustManifoldWithPotentialChokeHeatNipple.jpg) (315HemiIntakeShowingNoChokeHeatPad.jpg) Attachments ---------------- 58Dodge4bblIntake1735774.jpg (101KB - 184 downloads) 315HemiRightExhaustManifoldWithPotentialChokeHeatNipple.jpg (108KB - 192 downloads) 315HemiIntakeShowingNoChokeHeatPad.jpg (136KB - 180 downloads) | ||
Expert 5K+ Posts: 9672 Location: So. Cal | Hey, that 1st picture is my motor! Thanks. I didn't realize there were two different castings for the 315-325 4bbl intake. | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | Powerflite - 2021-01-19 12:30 PM Hey, that 1st picture is my motor! Thanks. I didn't realize there were two different castings for the 315-325 4bbl intake. Sorry. I didn't label the photo when I saved it as yours. Hope that using it was okay. I just realized that there probably wasn't a 4 bbl 241 manifold in 1953. There was in 1954 but it was made my Offenhauser for the Pace Cars (and clones). Never the less , you can just see the heat tube in this 54 Pace Car engine photo. Edited by 56D500boy 2021-01-19 5:07 PM (dodge_royal_convertible_indy_500_pace_car_4.jpg) Attachments ---------------- dodge_royal_convertible_indy_500_pace_car_4.jpg (150KB - 184 downloads) | ||
Phatton |
Veteran Posts: 174 Location: Camptown PA | Rather than electric - why not convert it to a manual choke? I did that with my factory 4 bbl and am very happy wit it. | ||
