55-56 Era Front Suspension Attachment Points and Weld Quality Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Expert 5K+ Posts: 9910 Location: Lower Mainland BC | . While I am in the process of replacing the water pump on my 56 Dodge V8 (315 D500 double rocker in this case), I got side tracked with the cleaning of many (65?) years of crud off the front frame rails and the suspension attachment points. I am posting because a) I am a bit shocked at the quality of welds and b) the difference between sides of the production line. The right side welds are much worse than the left side welds. Pride in workmanship or just better skills/experience? I realize that speed was the top priority, not how pretty the welds were. I also realize that once I paint the frame (Tremclad semi-gloss black rust paint), the welds are going to disappear. But still.... Edited by 56D500boy 2021-06-13 10:59 PM (56DodgeFrontFrameCrossMemberAndWelds_BeforePaint.jpg) (56DodgeFrontFrameCrossMemberAndWelds_BeforePaint_RightSide.jpg) (56DodgeFrontFrameCrossMemberAndWelds_BeforePaint_LeftSide.jpg) Attachments ---------------- 56DodgeFrontFrameCrossMemberAndWelds_BeforePaint.jpg (158KB - 202 downloads) 56DodgeFrontFrameCrossMemberAndWelds_BeforePaint_RightSide.jpg (154KB - 201 downloads) 56DodgeFrontFrameCrossMemberAndWelds_BeforePaint_LeftSide.jpg (172KB - 198 downloads) | ||
geoffs60 |
Veteran Posts: 165 Location: christchurch New Zealand | That looks incredabily clean what did you use besides a lot of tedious handywork. I am impressed. Geoff | ||
Expert 5K+ Posts: 9910 Location: Lower Mainland BC | geoffs60 - 2021-06-13 7:05 PM That looks incredibly clean what did you use besides a lot of tedious handywork. I am impressed. Thanks Geoff. It was tedious. ("The Zen of Cleaning Crud off an old car") 1. Long screw driver = long reach scraper 2. Wire brush in a cordless drill 3. Brass brush 4. Old tooth brush 5. Solvent 6. CRC Brake cleaner with a long red nozzle extension 7. Paper towels 8. Time 9. Time 10. More time I should have set a time limit, e.g. 4 hours. I think I let it go to about 6 hours in the end. The photos, which were only intended to show the difference in quality in the appearance of the welds, also show that I missed few spots. Tomorrow. | ||
Expert 5K+ Posts: 9910 Location: Lower Mainland BC | . Once I painted the frame and cross-member with semi-gloss Tremclad Professional (faster drying), the quality of the welding became a moot point. You can't really see now, so all's good. BEFORE (after Cleaning): AFTER (after painting): Edited by 56D500boy 2021-06-19 2:48 AM | ||
bbdakota |
Veteran Posts: 129 | Looking good! I'm considering going with hot heads adapters and a sbc water pump if mine ever gives out but so far, mines working fine. | ||
Expert 5K+ Posts: 9679 Location: So. Cal | I didn't realize that Dodge used the same motor mounts as the Plymouth 277. I'm guessing that was only for the 315. | ||
Stroller |
Extreme Veteran Posts: 371 | Amazing how much room there is once everything is out of the way. | ||
