heater box missing piece Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Landyacht67 |
Member Posts: 41 Location: Langley BC Canada | Hi I'm going to try and attach a pic, so wish me luck, but... on the heater box (under hood) there is the fan to the left with a 5" or so duct pointing to the drivers side of car. The heater box in the middle has a heater duct pointing to the passenger side. There's about a 1" gap between them. I'm guessing there's supposed to be a semi-flexible union between these. what has anyone used to replace this piece? also on passenger side of firewall there is a cable activated heat control valve. Mine has a small leak. Is there any replacements out there, or has anyone successfully modded from a more available model of car? | ||
Landyacht67 |
Member Posts: 41 Location: Langley BC Canada | apparently the attached pic did not work but oh well | ||
Landyacht67 |
Member Posts: 41 Location: Langley BC Canada | k I think I have it now (PXL_20210912_192129441.jpg) Attachments ---------------- PXL_20210912_192129441.jpg (101KB - 187 downloads) | ||
Expert 5K+ Posts: 9915 Location: Lower Mainland BC | Landyacht67 - 2021-09-12 3:25 PM also on passenger side of firewall there is a cable activated heat control valve. Mine has a small leak. Is there any replacements out there, or has anyone successfully modded from a more available model of car? Lots of heater valve info, including rebuilding and/or replacing, in these threads: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=67959&... and http://www.forwardlook.net/forums/forums/thread-view.asp?tid=69334&... Edited by 56D500boy 2021-09-12 7:16 PM | ||
Landyacht67 |
Member Posts: 41 Location: Langley BC Canada | 56D500boy - 2021-09-12 3:45 PM Landyacht67 - 2021-09-12 3:25 PM also on passenger side of firewall there is a cable activated heat control valve. Mine has a small leak. Is there any replacements out there, or has anyone successfully modded from a more available model of car? Lots of heater valve info, including rebuilding and/or replacing, in this thread: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=67959&... thanks that's awesome. just a question, the heater control valve from volvo has that heat tube on it. I don't see one on the factory or if there's supposed to be one maybe its snapped off? Does everyone just find a way to plumb that tube into the heat box, float it in the interior, or disable it? Didn't see anything with a recommendation on that. | ||
finsruskw |
Expert Posts: 2289 Location: Eastern Iowa | It's basically a small section of rubber tube that slides over both pieces. Think short piece of inner tube. | ||
Expert 5K+ Posts: 9915 Location: Lower Mainland BC | Landyacht67 - 2021-09-12 3:34 PM k I think I have it now You are looking for item 15, which is PN 1689 674. Which you can see in this photo. Just a big rubber band. In a pinch, you could accomplish what needs to be done with black duct tape (I'll never tell): (I just searched Hiltop Mopar, Len Dawson Mopar and Grease Monkey Garage with "1689674" and came up with nothing. You could try Andy Bernbaum, Steele Rubber, Kanter and/or Quirey/Gary Goers) Edited by 56D500boy 2021-09-12 7:30 PM | ||
Landyacht67 |
Member Posts: 41 Location: Langley BC Canada | awesome, thanks!! | ||
dels56 |
Extreme Veteran Posts: 355 | If you have not already found the rubber band, why don't you go to a tire shop and see if the have a junk inner tube (they are still used). Cut a piece out of the tube the length to suit. Del S | ||
Skelly1958 |
Regular Posts: 86 Location: MN | Quirey should still have it. I got one from Gary Goers not long before he sold the business to Quirey. | ||
1959 Belvedere Conv |
Elite Veteran Posts: 1107 Location: Arvada, Colorado (NW Denver Metro Area) | I did not see if anyone answered you on the missing part from the fan to the heater box/plenum. It is a large and wide rubber band size piece of rubber that seals that cap. I will take a pic of mine today and send it to you. I may have an extra one of these you can have for free, just pay postage. John | ||
