241 270 315 Poly Parts & Bellhousings Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Forward Look Swap Meet -> For Sale - PARTS | Message format |
Expert 5K+ Posts: 9703 Location: So. Cal | I recently acquired this '54 Dodge 241 engine (D502 stamping) along with some 315 poly heads & exhaust manifolds. I am in the process of tearing the motor down, so I am willing to sell off parts if you need them. The bellhousings are also for sale, though I would like to know what they each fit. The transmissions are different from each other. Does anyone recognize them? I also have 2 water pumps. I believe the one on the left is from a 270 truck. I have no idea what that exhaust manifold at the bottom left fits. Anyone know? I would guess flathead Ford, but I am just guessing. The distributor shown here is for a straight 6, but I have a bunch of the early hemi versions for sale too. The hemi heads in the picture are not for sale, but I would appreciate any help with how to remove those spark plug tubes as they are stuck solid in there. Heat didn't seem to work on them, but it's hard to really heat it well enough to make a difference. Edited by Powerflite 2022-03-13 1:47 AM (315 241 Parts For Sale.jpg) (270 241 Water Pumps.jpg) Attachments ---------------- 315 241 Parts For Sale.jpg (221KB - 72 downloads) 270 241 Water Pumps.jpg (139KB - 76 downloads) | ||
58coupe |
Expert Posts: 1740 Location: Alaska | Don't see any transmissions? I think the center ex. on flathead fords is combined into one so not sure that is ford. | ||
Expert 5K+ Posts: 9703 Location: So. Cal | Thanks. I was talking about the mounting patterns on the bellhousings. I would like to know which transmissions they would work for. | ||
58coupe |
Expert Posts: 1740 Location: Alaska | The upper bell looks like for your 241 used up to about 55 and appears to be double drilled for auto and truck trans. The lower one looks like a later unit used from 56 on after Chrysler went to the side engine mounts. | ||
hondaman1974 |
Veteran Posts: 189 Location: Northern Illinois | Nathan, might be interested in the intake and carb, whats the carb number? intake casting number? Edited by hondaman1974 2022-03-15 9:35 PM | ||
Expert 5K+ Posts: 9703 Location: So. Cal | The carb came in a box labeled: '57 Dodge truck 315. I can't find any numbers on it, but it does look like the carb on my '57 truck, except mine uses an automatic choke, and this carb is setup for for a manual, cable operated choke. Funny though because my truck has the cable with a broken piece of carburetor on the end of it, so I might have swapped in the choke at a later date, but I can't remember now. I don't think that it has been rebuilt, so not sure why it was in the box. But it seems to be in good shape. | ||
Expert 5K+ Posts: 9703 Location: So. Cal | Intake casting number is 1409375-2 | ||
Expert 5K+ Posts: 9703 Location: So. Cal | I found out what the odd exhaust manifold at the lower left fits: '50-'71 Jeep/Willys 4cyl F134 | ||
hondaman1974 |
Veteran Posts: 189 Location: Northern Illinois | looks like i cant use the carb, does the intake have the coil bracket and throttle spring perch as "one piece"? thanks | ||
Expert 5K+ Posts: 9703 Location: So. Cal | Yes, the bottom part of the coil bracket is the same piece as the spring perch. | ||
hondaman1974 |
Veteran Posts: 189 Location: Northern Illinois | thanks nathan, im interested in the coil bracket | ||
Expert 5K+ Posts: 9703 Location: So. Cal | It looked like it was one piece, but after taking it apart, the spring mount is a separate part that the coil bracket sits on. Do you still want it? (241 Hemi Coil Bracket.jpg) Attachments ---------------- 241 Hemi Coil Bracket.jpg (105KB - 65 downloads) | ||
hondaman1974 |
Veteran Posts: 189 Location: Northern Illinois | pm sent | ||
