Poly A Block Head Street Porting Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
PolyJ |
Veteran Posts: 144 Location: Denver, Colorado, USA | I'm making progress on the 390 stroker poly A-block build. I finished street porting the head and intake manifold runners, and the heads are at my machinist's having 2.02"/1.60" race valves and new guides installed. He's going to make the 70° seat cut and give the heads back to me so I can blend the bowls and finish the porting job before he goes back in and finishes the valve job. I wrote up a porting tech article for those who want to follow along or are interested in street porting A-block heads since they flow really well when street ported: https://poly318.com/poly-cylinder-head-porting.html I also modified the intake manifold to open up the plenum and gasket-match it to the Offenhauser cross-ram adapters. The intake required a lot of material to come off the runners to match the gasket. I also epoxied up the exhaust crossover. A complete description of the work is at https://poly318.com/poly-intake-manifold-porting.html
(intake_runner_ported.jpg) (Exhaust_ported1.jpg) (head_ported_intake.jpg) (manifold2_gasket_marked.jpg) (Manifold_Ported_resized.jpg) (Manifold4b.jpg) (manifold4a.jpg) (Manifold_Ported1_resized.jpg) Attachments ---------------- intake_runner_ported.jpg (166KB - 124 downloads) Exhaust_ported1.jpg (225KB - 125 downloads) head_ported_intake.jpg (181KB - 119 downloads) manifold2_gasket_marked.jpg (224KB - 122 downloads) Manifold_Ported_resized.jpg (141KB - 125 downloads) Manifold4b.jpg (197KB - 127 downloads) manifold4a.jpg (184KB - 129 downloads) Manifold_Ported1_resized.jpg (124KB - 124 downloads) | ||
Expert 5K+ Posts: 9703 Location: So. Cal | Keep in mind that once you start opening up the intake manifold at the carb mounts, that you can no longer run the original WCFBs on it. They won't seal all their ports properly. Nice job on the head porting. Were you able to do a flow test before and after? Edited by Powerflite 2022-05-18 11:22 PM | ||
PolyJ |
Veteran Posts: 144 Location: Denver, Colorado, USA | Powerflite - 2022-05-18 9:20 PM Keep in mind that once you start opening up the intake manifold at the carb mounts, that you can no longer run the original WCFBs on it. They won't seal all their ports properly. Nice job on the head porting. Were you able to do a flow test before and after? Thanks. Correct on the WCFBs. If I ever ditch the cross-ram setup, I'd run the dual AFBs with adapter spacers that would seal. I don't care for WCFBs compared to AFBs, AVSs, or Holley 4150s.
