New User
| Hi, my '58 Belvedere is sidelined yet again. This time it was for a transmission rebuild and now it looks like I need a driveshaft as well. Basically, the local driveshaft guy says the hole at the "pin" end has worn and is too loose for a rebuild. If anyone has a less worn example they are willing to part with I would be interested.
My car:
'58 Belvedere 2 dr HT
318 Poly with 3 speed Torqueflite
(20220614_172451.png)
Attachments ---------------- 20220614_172451.png (408KB - 153 downloads)
Location: Muskego, WI | Why can't you have a machine shop bore out the hole true and then sleeve/bush it to the proper size? |
New User
| I had considered that. There might be an issue with not very much metal around that pinion to be able to safely bore it out and sleeve it. I'm looking at a couple of options but the easiest would have been to just replace the driveshaft, if I could find one. |
Location: Muskego, WI | Try Big M Auto in California, he has tons of FL cars. |
Location: WHEELING,WV.>>>HOME OF WWVA | get a slip shaft made!! --------------------------------------later |
