34 Airflow![]() |
Veteran Posts: 217 ![]() ![]() Location: Echuca | Has anyone ever bought these drums? I have had endless issues with the drums on my New Yorker and though I may just start from scratch as I do want to keep the car original. I have read the drum and hub has to be matched?
Edited by 34 Airflow 2023-01-15 7:17 PM (57 Brake Drums.png) Attachments ---------------- ![]() | ||
Powerflite![]() |
Expert 5K+ Posts: 9746 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: So. Cal | If you have a drum cutter to true the drum after you have attached them to the hubs, then there isn't a problem with them. It's just a lot easier to buy good used drums instead. | ||
ronbo97![]() |
Expert Posts: 4075 ![]() ![]() ![]() ![]() ![]() Location: Connecticut | 34 Airflow - 2023-01-15 7:14 PM Has anyone ever bought these drums? I have had endless issues with the drums on my New Yorker and though I may just start from scratch as I do want to keep the car original. I have read the drum and hub has to be matched? Do not buy repro drums. The factory drum and hub were centered and aligned as a one-piece assembly. If you separate the two, you will lose that alignment and your drums will never work properly. You will experience endless chattering, pulling and reduced braking. Is that what you want ? What problems are you having with your drums ? What year is your car ? Have you had the drums turned ? Are they still in spec ? Are they warped ? Ron | ||
34 Airflow![]() |
Veteran Posts: 217 ![]() ![]() Location: Echuca | ronbo97 - 2023-01-16 12:13 PM 34 Airflow - 2023-01-15 7:14 PM Has anyone ever bought these drums? I have had endless issues with the drums on my New Yorker and though I may just start from scratch as I do want to keep the car original. I have read the drum and hub has to be matched? Do not buy repro drums. The factory drum and hub were centered and aligned as a one-piece assembly. If you separate the two, you will lose that alignment and your drums will never work properly. You will experience endless chattering, pulling and reduced braking. Is that what you want ? What problems are you having with your drums ? What year is your car ? Have you had the drums turned ? Are they still in spec ? Are they warped ? Ron
HI Ron, Thanks for the info, I had thought I had heard about the drum and hub being matched. My car is a 57 New Yorker and I have issues with rear brakes grabbing, we have replaced wheel cylinders, hoses, shoes and the next step is to machine the drums. The brake guys I use out here asked the question of replacement drums so I thought I should look into it. Trav | ||
Viper Guy![]() |
Expert Posts: 2004 ![]() Location: Branson, MO | It may not be your drums. It could be your shoes causing the grabbing. It they are old, they could be impregnated with moisture or other contaminants and causing the grabbing. If you drag your brakes while moving slowly (heats them up), will the grabbing stop or lessen? If so, change your shoes and the problem may be solved. | ||
wizard![]() |
Board Moderator & Exner Expert 10K+ Posts: 13062 ![]() ![]() ![]() ![]() ![]() ![]() Location: Southern Sweden - Sturkö island | What Viper Guy writes - check the brake shoes first of all. That said, I have separated all four drums from the hubs, first making a small reference hole so that I can mount them as they was assembled. That way the balance remains and I get very easy access to the brakes on long roadtrips. The rear drums is next to impossible to remove by the roadside if something should need service. The front drums is not the same drama, but with my modification it's very easy and fast. Tested the car over 100 mph, no vibrations, very good brake effect (fading of course) no problems. The *** drums are most probably not balanced and surely of poor quality. My drums have 17000 miles and still very nice, I suspect that the brake shoes have the same 17000 miles on them - asbethos of course. | ||
ronbo97![]() |
HI Ron, Thanks for the info, I had thought I had heard about the drum and hub being matched. My car is a 57 New Yorker and I have issues with rear brakes grabbing, we have replaced wheel cylinders, hoses, shoes and the next step is to machine the drums. The brake guys I use out here asked the question of replacement drums so I thought I should look into it. Trav I highly recommend doing your own brake work. The guys working on your car likely know little-to-nothing about late 50s Chrysler brakes. Do they have a tapered axle drum puller, so that they can correctly pull the drum/hub assembly ? It sounds like they are fans of 'just throw enough parts at it until the problem goes away' school of thought, so they can charge you $$$$$ for replacement of parts that may still be good. Ron Edited by ronbo97 2023-01-16 11:59 AM | ||
34 Airflow![]() |
Veteran Posts: 217 ![]() ![]() Location: Echuca | Thanks for the info guys! We replaced the wheel cylinders as they were leaking and the hoses were questionable so figured whilst we were getting parts shipped to Australia we would get shoes while we were at it. Freight is more expensive than the parts so I try and get everything in one go to make it more worthwhile. Ron you are probably right about not having great knowledge of 50's Chryslers, almost impossible to find let alone in a small town of 12,000 people that I live in. The friend who owns the workshop I use was onto the tapered drum puller so at least we ticked that box. The two hex adjusters are free, I will make sure we get those apart and cleaned right out as it could be something like that hopefully. | ||
ronbo97![]() |
Expert Posts: 4075 ![]() ![]() ![]() ![]() ![]() Location: Connecticut | 34 Airflow - 2023-01-16 7:23 PMThe two hex adjusters are free, I will make sure we get those apart and cleaned right out as it could be something like that hopefully. Just to clarify, don't take the adjusters apart ! You will destroy the center support. Just remove the center support assembly. Then clean it out and dry it off. Verify that the adjusters still move when you put a socket on them. Ron | ||
34 Airflow![]() |
Veteran Posts: 217 ![]() ![]() Location: Echuca | ronbo97 - 2023-01-17 11:47 AM 34 Airflow - 2023-01-16 7:23 PMThe two hex adjusters are free, I will make sure we get those apart and cleaned right out as it could be something like that hopefully. Just to clarify, don't take the adjusters apart ! You will destroy the center support. Just remove the center support assembly. Then clean it out and dry it off. Verify that the adjusters still move when you put a socket on them. Ron
Thanks for the tip Ron! | ||
