Location: The Mile High City | The prototypes went pretty well for an initial effort, but there are a lot of refinements to be done! The 3-D printing process is amazing, but I need a much sharper print. Painting is the easiest part, but I think I need to incorporate metallic foil to make it better. The thick urethane coat was a bubbly, uneven failure. I need a better substitue, maybe a resin.
(Prototype 3 reduced.jpg)
(Prototype 4 reduced.jpg)
(Prototype 5 reduced.jpg)
(Prototype 6 reduced.jpg)
Attachments ---------------- Prototype 3 reduced.jpg (246KB - 83 downloads) Prototype 4 reduced.jpg (244KB - 80 downloads) Prototype 5 reduced.jpg (240KB - 81 downloads) Prototype 6 reduced.jpg (231KB - 77 downloads)
Location: The Mile High City | Still working on this project. I was able to order a set of the "wheelcover center emblems that never were" from Xometry and they printed in stereolithography with Accrua xtreme grey material - and the quality was pretty good. I think the cost was about $160. Painting them was a bit of a challenge, but I think they are decent enough to replace the Chrysler centers that are in there now. They are not exquisite quality on close inspection, but I think they will be decent from a distance of just a couple of feet away.
(01 first coat red.jpg)
(02 second coat white and black.jpg)
(03 third coat light gold.jpg)
(04 fourth coat yellow.jpg)
(05 final clear coat.jpg)
Attachments ---------------- 01 first coat red.jpg (85KB - 25 downloads) 02 second coat white and black.jpg (188KB - 27 downloads) 03 third coat light gold.jpg (190KB - 24 downloads) 04 fourth coat yellow.jpg (243KB - 26 downloads) 05 final clear coat.jpg (111KB - 25 downloads)
Location: SWITZERLAND | Mike, put the red paint at least, must be quite liquid and flow. Before do paint the emblems somewhat "over" the border. Then the color separation will become very accurate, as I did with some knight emblems when golden coating. And use paint which is not aggressive to the resin. Good Luck! - SERGE -
Edited by sermey 2024-02-09 1:35 PM
Location: The Mile High City | Thanks, Serge! Working on the Adventurer emblems now. So far, they have been easier to paint. I started with gold and then masked off the gold to apply the silver background. I tried to mask off the silver and gold to apply the black, but ended up having to hand paint the black with gloss enamel. Still need to apply the clear-coat.
(Adventurer Center Emblems reduced.jpg)
Attachments ---------------- Adventurer Center Emblems reduced.jpg (237KB - 0 downloads)
