1959 Dodge D500 authentication question Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Hemi Joel |
Member Posts: 16 Location: Minnesota | Hi, is there a way to verify if a 1959 Dodge was originally D500 or Super D500 versus a car that had that option added later? Also, what are all of the attributes of these options versus the standard engine? Hopefully there is a 1959 Dodge Custom Royal lancer out there somewhere just waiting to find its way into my garage. And if it is a D500, all the better! Thanks, Joel | ||
frwl |
Expert Posts: 1898 | . The 1959 Dodge D500 option has order code 373; Super D500 option – order code 374. Those codes should be printed on the built sheets. If the car has not a sheet, you may find needful code on the cowl tag under the hood. No code – no factory D500 option. Firstly, you need to find the Serial Number of the car. 1959 Dodge has 10-digit VIN: 1st position – Model Year: M – 1959; 2nd position – Division of Chrysler Corporation: 3 – Dodge; 3rd position – Model: 1 – Coronet V8 3 – Royal V8 5 – Custom Royal V8 7 – Sierra Wagons V8 9 – Police Pursuit Cars V8 4th position – Assembly Plant: 2 – Hamtramck, Detroit, Michigan 4 – Los Angeles, California 5 – Newark, Delaware 9 – Windsor, Ontario, Canada So, if you want to have a Custom Royal Lancer in your garage, the VIN of your car will be starting at M35… The most common 1959 Dodge D500 broadcast sheets and cowl tags pictures for identification shown below. | ||
frwl |
Expert Posts: 1898 | . The Hamtramck Plant broadcast sheet and cowl tag – the fourth VIN character is “2”, i.e. M352xxxxxx for Custom Royal. Find the column 37 “POWER PLANTS” on the sheet with printed “3” above, or see at the 8th column from the left in the middle row on the cowl tag. It is “36” with “3” stamped below. Each of these tells this is D500. No mistake to “36” on the data plate. The tag code 363 means order code 373. Those are different things. (Hamtramck Built Sheet.jpg) (Hamtramck Cowl Tag.jpg) Attachments ---------------- Hamtramck Built Sheet.jpg (85KB - 52 downloads) Hamtramck Cowl Tag.jpg (94KB - 56 downloads) | ||
frwl |
Expert Posts: 1898 | . The Los Angeles Plant broadcast sheet and cowl tag – the fourth VIN character is “4”, i.e. M354xxxxxx for Custom Royal. Find the column 37 “POWER PACKAGE” on the sheet with printed “3” above, or see at the M2 slot on the cowl tag with “3” stamped below. Each of these tells this is D500. (Los Angeles Built Sheet.jpg) (Los Angeles Cowl Tag.jpg) Attachments ---------------- Los Angeles Built Sheet.jpg (171KB - 52 downloads) Los Angeles Cowl Tag.jpg (57KB - 54 downloads) | ||
frwl |
Expert Posts: 1898 | . The Delaware Plant broadcast sheet and cowl tag – the fourth VIN character is “4”, i.e. M355xxxxxx for Custom Royal. Find the column 37 “ENG” on the sheet with printed “3” below, or just see on the cowl tag with “373” stamped on it. Each of these tells this is D500. (Delaware Built Sheet.jpg) (Delaware Cowl Tag.jpg) Attachments ---------------- Delaware Built Sheet.jpg (76KB - 60 downloads) Delaware Cowl Tag.jpg (110KB - 53 downloads) | ||
frwl |
Expert Posts: 1898 | . The Canadian Windsor Plant cowl tag – the fourth VIN character is “9”, i.e. M359xxxxxx for Custom Royal. No broadcast sheet picture, unfortunately. You may find the cowl tag near right hood hinge, but no info about D500 on it. In this case the broadcast sheet only will help you. (Windsor Cowl Tag.jpg) Attachments ---------------- Windsor Cowl Tag.jpg (82KB - 58 downloads) | ||
frwl |
Expert Posts: 1898 | frwl - 2023-08-27 8:20 AM . The Delaware Plant broadcast sheet and cowl tag – the fourth VIN character is “4”, i.e. M355xxxxxx for Custom Royal. Find the column 37 “ENG” on the sheet with printed “3” below, or just see on the cowl tag with “373” stamped on it. Each of these tells this is D500. the fourth VIN character is “5”, i.e. M355xxxxxx for Custom Royal | ||
Hemi Joel |
Member Posts: 16 Location: Minnesota | FRWL, that is great info, just what I needed. Thanks very much! | ||
Expert 5K+ Posts: 9911 Location: Lower Mainland BC | frwl - 2023-08-27 5:21 AM The Canadian Windsor Plant cowl tag – the fourth VIN character is “9”, i.e. M359xxxxxx for Custom Royal. No broadcast sheet picture, unfortunately. You may find the cowl tag near right hood hinge, but no info about D500 on it. In this case the broadcast sheet only will help you. The Canadian cowl data tags are the worst. Bill W (Chrycoman) was good at interpreting them but in reality, they really don't contain much info. | ||
