| Hi has anyone got any info on how to go about changing upper and lower control arm bushes thanks in advance Phil |
Location: Eastern Iowa | Get yourself a copy of the FSM for that year.
It's all in there and can be downloaded here.....
http://www.jholst.net/300resource/index.php
Unfortunately, the FSM shows the use of dedicated tooling that few, if any, have...so this calls for some Yankee Ingenuity.
Personally, I use an H-frame press and an assortment of tubing scraps to press the bushings out and in. I'm sure others here have their pet methods that they can pass along. |
Location: So. Cal | Large 1/2" drive socket sets are really useful for this purpose because they come in a wide assortment of sizes, and you can use the extensions to make them longer, like an erector set.
(58Coronet UCA Press.jpg)
Attachments ---------------- 58Coronet UCA Press.jpg (111KB - 58 downloads)
| Thanks for the replies Phil |
