1956 and 1957 Dodge D500 Hemi Wire Cover Slot Dimensions
Posted 2024-01-08 9:32 PM (#633337)
Subject: 1956 and 1957 Dodge D500 Hemi Wire Cover Slot Dimensions
500020002000500100100100100252525
In case you end up with Dodge Hemi wire covers that don't fit over the solid lifter adjustment bumps on a 56 or 57 D500 hemi valve cover,'
here are some dimensions that you could use to cut your own bump "relief"s. Hope this helps somebody.
(And, yes I know 57 D500s had hydraulic lifters but somebody in the valve cover department apparently didn't get the "Delete the Bumos" memo. )
This one is for the passenger side of the engine. The driver's side is probably different at the ends but the main spacing dimensions will be the same.
Edited by 56D500boy 2024-01-08 9:38 PM
(56Dodge315HemiSparkPlugWireCover_RightSide_Annotated.jpg)
Attachments 56Dodge315HemiSparkPlugWireCover_RightSide_Annotated.jpg (104KB - 42 downloads)
Posted 2024-01-12 9:19 PM (#633376 - in reply to #633337)
Subject: RE: 1956 and 1957 Dodge D500 Hemi Wire Cover Slot Dimensions
Just to follow up with a bit more info.
1. And by "Delete the Bumos", I obviously meant "Delete the BumPs" (used to clear the exhaust valve adjustable rockers)
2. The spark plug tube seals are held to the valve cover by metal retaining rings about 1/8" (maybe 3/32" ?) thick with the dimensions as shown below.
3. The retaining rings are held down by the wire covers, as shown below.
Incidentally, the rubber tube seals were common to all the 55-58 hemis, i.e. PN 1324 940. Likewise the metal retaining rings, PN 1324 941, common for all the 55-58 hemis.
Hope that helps somebody.
(315DodgeD500HemiShowingSparkPlugTubeSealAndWire_RetainingRingInPlace.jpg)
(315DodgeD500HemiShowingSparkPlugTubeSealAndWire_RetainingRingRemoved.jpg)
(315DodgeD500HemiShowingSparkPlugTubeSealRetainingRing_OuterDiameter.jpg)
(315DodgeD500HemiShowingSparkPlugTubeSealRetainingRing_OuterDiameter_Detail.jpg)
(315DodgeD500HemiShowingSparkPlugTubeSealRetainingRing_InnerDiameter_Detail.jpg)
(315DodgeD500HemiSizeOfRetainingRingComparedToWireCover.jpg)
(SparkTubeSealAndRetainingRingPNsWithSparkPlugInfo.jpg)
Attachments 315DodgeD500HemiShowingSparkPlugTubeSealAndWire_RetainingRingInPlace.jpg (139KB - 39 downloads)
Attachments 315DodgeD500HemiShowingSparkPlugTubeSealAndWire_RetainingRingRemoved.jpg (140KB - 41 downloads)
Attachments 315DodgeD500HemiShowingSparkPlugTubeSealRetainingRing_OuterDiameter.jpg (139KB - 44 downloads)
Attachments 315DodgeD500HemiShowingSparkPlugTubeSealRetainingRing_OuterDiameter_Detail.jpg (146KB - 43 downloads)
Attachments 315DodgeD500HemiShowingSparkPlugTubeSealRetainingRing_InnerDiameter_Detail.jpg (148KB - 48 downloads)
Attachments 315DodgeD500HemiSizeOfRetainingRingComparedToWireCover.jpg (144KB - 51 downloads)
Attachments SparkTubeSealAndRetainingRingPNsWithSparkPlugInfo.jpg (149KB - 51 downloads)
