1956 dodge passenger car rear springs
tailfins
Posted 2024-02-15 11:09 PM (#633770)
Subject: 1956 dodge passenger car rear springs
1000500100100252525
were 5 leaf standard on all models?
which came with 6 leaf?
thanks
Posted 2024-02-15 11:14 PM (#633771 - in reply to #633770)
Subject: RE: 1956 dodge passenger car rear springs
500020002000500100100100100
tailfins - 2024-02-15 8:09 PM
Charlie: I have investigated 56 Dodge rear leaf springs extensively, before. The number of leaves in the rear springs varied from 4 to 7 depending on the service, the body type and the engines.
REFERENCE: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=78042&...
Edited by 56D500boy 2024-02-16 2:00 AM
tailfins
Posted 2024-02-16 11:14 AM (#633776 - in reply to #633770)
Subject: Re: 1956 dodge passenger car rear springs
1000500100100252525
thanks, my 56 coronet convertible has 5 leaf springs and big brakes so this helps identify as an orig hemi car
Posted 2024-02-18 1:30 PM (#633779 - in reply to #633776)
tailfins - 2024-02-16 8:14 AM
With the Forward Look system down, since Friday, I missed your response Charlie.
The only way to confirm that your car was an original D500 hemi car would be to get the IBM card from Danielle Szostak at Stellantis Historical.
If you email Danielle Szostak at Stellantis Historical (formerly Chrysler Historical) at danielle.szostak@stellantis.com
with a scan of your 56 Dodge registration/ownership papers with your details and the cars's VIN number to prove that you are the owner of the car, I believe that she will be
able to send you a pdf copy of the microfiche images of the IBM cards. The IBM card will show the engine number. D500-nnnn for the D500 hemi and D63-nnnnn for the poly.
In the meantime, try to get a photo of the spring number that is stamped into one of the bottom leaves, like this:
